Онлайн всего: 600
Гостей: 454
Пользователей: 146
Gashan4ik, master0611, ejo6851, ludovic, mailgayfa, RishatPau, Vadim1990, n-sergt, steff-nm, adekvat174, voltor, Gelios04, Zahiu, andymon, tabolaevavika, Warmonger_UA, electronic_arash, xharom, skyline37, masterlis1984, ZimA, max844, Yura1973, Michal, marsello2010, Waldo240, Led, excalidor, jp66, kalashns, exspeditio93, igor79sobol, SerZZ, Abapel, Техком, lukshas, ravil-5, banka15, Boomrik, sav-fitco, UT5QAI, polaris2, drimok1, Scholes121, ssaransk, Vovanchik, Sinokor, tdimon70, tehnik129, KVAZAR94, [Полный список]
Приветствую Вас, Гость · RSS 12.11.2026, 13:03:15
Главная » Статьи » Статьи » Аудиоаппаратура
Microlab M-860 – Repair Guide: Power On but No Standby... Руководство по ремонту: питание есть, но режим Standby не включается
Here is the summary of the diagnostic and repair method for the Microlab M-860 no-standby issue in both English and Russian:
### **English Summary**
**Issue:**
The unit turns on (power is present), but the MCU fails to enter Standby mode (Front-panel Standby LED remains off, and the system is completely unresponsive).
**Root Cause:**
The MCU's Reset pin (**Pin 4: MCLR/RESET**) was stuck at **0V**. The original pull-up resistor connected to Pin 4 had failed (open circuit or drifted in value), preventing the MCU (`SG16C56` / `PIC16C56` DIP-18 package) from exiting its reset state to boot the firmware.
**Pinout Reference (`SG16C56` / `PIC16C56`):**
* **Pin 4:** `MCLR` (Reset)
* **Pin 5:** `VSS` (GND)
* **Pin 14:** `VDD` (+5V Power Supply)
**Resolution / Repair Steps:**
1. **Remove / Isolate 2N5551:** Desolder the `2N5551` transistor connected to Pin 4 temporarily during testing to ensure it is not pulling the Reset line to Ground.
2. **Force-Boot / Bypass Reset Line:** Jump a **$1.5\,\text{k}\Omega$ Resistor** directly from **Pin 14 (`VDD` / +5V)** to **Pin 4 (`MCLR` / Reset)** on the MCU solder side.
3. **Verification:** Power on the unit. Pin 4 should now measure **+4.5V to +5.0V DC**. The Standby LED will illuminate, and turning the master volume knob will wake the unit into active mode.
4. **Final Assembly:** Reinstall the `2N5551` transistor and permanently secure the $1.5\,\text{k}\Omega$ resistor (or replace the failed SMD/DIP pull-up resistor on the board with $1.5\,\text{k}\Omega - 10\,\text{k}\Omega$).
### **Русский перевод (Russian Summary)**
**Проблема:**
Питание на устройство подается, но микроконтроллер (MCU) не переходит в режим ожидания (светодиод Standby на передней панели не горит, система не реагирует на нажатия).
**Причина неисправности:**
На выводе сброса микроконтроллера (**Pin 4: MCLR/RESET**) присутствует **0В**. Штатный подтягивающий резистор (Pull-up), подключенный к выводу 4, вышел из строя (обрыв или увеличение сопротивления), из-за чего MCU (`SG16C56` / `PIC16C56` в корпусе DIP-18) постоянно находится в состоянии сброса и не может загрузиться.
**Распиновка микроконтроллера (`SG16C56` / `PIC16C56`):**
* **Вывод 4:** `MCLR` (Сброс / Reset)
* **Вывод 5:** `VSS` (Земля / GND)
* **Вывод 14:** `VDD` (Питание +5В)
**Инструкция по ремонту:**
1. **Демонтаж транзистора 2N5551:** На время диагностики выпаяйте транзистор `2N5551`, соединенный с выводом 4, чтобы исключить замыкание линии сброса на землю.
2. **Принудительный запуск (Перемычка):** Припаяйте резистор **1.5 кОм** непосредственно между **выводом 14 (`VDD` / +5В)** и **выводом 4 (`MCLR` / Reset)** микроконтроллера.
3. **Проверка:** Включите питание. Напряжение на выводе 4 должно подняться до **+4.5В ... +5.0В DC**. Светодиод Standby загорится, а при вращении регулятора громкости система перейдет в рабочий режим.
4. **Завершение ремонта:** Установите транзистор `2N5551` обратно и зафиксируйте резистор 1.5 кОм (либо замените сгоревший SMD/DIP подтягивающий резистор на плате на аналог номиналом 1.5 кОм – 10 кОм).
**Microlab M-860 – Repair Approach for “Power On but No Standby” Failure**
**Symptom:**
* AC power is present.
* The +5V supply is present.
* The standby LED does not turn on.
* The unit does not respond to the front volume/power control.
* Normally, turning the volume knob should wake the unit from standby, but after the failure the unit remains completely inactive.
**Repair / Modification Approach:**
The suspected problem is in the standby/control circuit rather than the main power amplifier section.
A practical modification is to provide a controlled bias voltage to **Pin 4** of the control IC by connecting it to the positive supply through a **1.5 kΩ resistor**.
**Connection:**
**+5V → 1.5 kΩ resistor → Pin 4**
The resistor should be connected in series between the +5V supply and Pin 4. Do not connect +5V directly to Pin 4 without the resistor.
**Purpose of the 1.5 kΩ resistor:**
* Provides a limited current to Pin 4.
* Forces the control circuit toward the required logic state.
* Allows the standby/control section to start when the original wake-up circuit is no longer functioning.
* The resistor also provides protection against excessive current compared with a direct jumper.
**Important:**
Before making the modification, confirm the actual IC pin numbering and the voltage normally expected at Pin 4 from the original circuit diagram. The modification should only be made if Pin 4 is confirmed to be the correct standby/control input.
After installation:
1. Measure the voltage at Pin 4.
2. Check that the standby LED operates correctly.
3. Check whether the unit can be switched between standby and operating states.
4. Check the output channels and subwoofer for abnormal DC voltage or excessive noise.
5. Monitor the resistor and IC for abnormal heating.
This modification should be treated as a troubleshooting/repair modification rather than an assumption that the original circuit design used this exact method.
**Microlab M-860 — ремонт при неисправности «питание есть, но Standby не работает»**
**Симптомы:**
* Сетевое питание присутствует.
* Напряжение +5 В присутствует.
* Индикатор Standby не загорается.
* Передняя ручка Volume/Power не может вывести аппарат из режима ожидания.
* В нормальном состоянии после включения питания поворот ручки громкости должен активировать аппарат, но после неисправности устройство остаётся полностью неактивным.
**Предлагаемый способ ремонта / модификации:**
Предположительно неисправность находится в цепи управления Standby, а не в основном усилителе мощности.
Для проверки и восстановления работы можно подать управляющее напряжение на **вывод 4 управляющей микросхемы** через резистор **1,5 кОм**, подключив его к положительной линии питания.
**Схема подключения:**
**+5V → резистор 1,5 кОм → вывод 4**
Резистор должен быть установлен последовательно между +5 В и выводом 4. Не следует соединять +5 В с выводом 4 напрямую без резистора.
**Назначение резистора 1,5 кОм:**
* Ограничивает ток, поступающий на вывод 4.
* Создаёт необходимый уровень управляющего сигнала.
* Помогает перевести управляющую схему из состояния Standby в рабочее состояние.
* Защищает управляющую цепь от чрезмерного тока по сравнению с прямым соединением +5 В с выводом 4.
**Важно:**
Перед выполнением модификации необходимо точно проверить нумерацию выводов микросхемы и штатное напряжение на выводе 4 по оригинальной схеме M-860. Подключение +5 В через 1,5 кОм следует выполнять только после подтверждения, что вывод 4 действительно является соответствующим входом/узлом управления Standby.
После установки резистора необходимо:
1. Измерить напряжение непосредственно на выводе 4.
2. Проверить работу индикатора Standby.
3. Проверить включение и переход между Standby и рабочим режимом.
4. Проверить все выходные каналы и сабвуфер на наличие постоянного напряжения DC или сильного шума.
5. Проверить резистор и управляющую микросхему на предмет чрезмерного нагрева.
Данная операция является ремонтной/диагностической модификацией и не должна рассматриваться как подтверждение того, что именно такая схема использовалась производителем в оригинальной конструкции.
Материал добавил: ickilas, 04.10.2026(Воскресенье) в 05:36:06 | Категория: Статьи / Аудиоаппаратура | Просмотров: 278 | Комментариев: 0 | Понравилось: 0 |
Pioneer FH-X730BT ошибка -19.
Платформа: Compal LA-C811P Rev 1.0 (Diner Braswell...
Видеоурок
HP 14-ax000ur замена EMMC с 32 на 128 Гб
Формирование напряжений и сигналов запуска ноутбук...
доработка паяльника
Тестер компьютерного блока питания
Процесс прошивки на примере MP3 плеера ipod на пр...
Ремонт портативной колонки Sven PS-650
ремонт аудиосистемы DEXP V460
